Set up Help
All Optrix VideoPro related discussions
CKAVolvo
Set up Help
Post by CKAVolvo »
I am having a hard time getting my Ipod5 to work with Video, in the System Status I get the following results
Red
Not Ready
GPS Update Rate
Accuracy
Track Nearby
Yellow
Lo Res
Video
Calibration
Green
Ipod triangulation
Storage 50GB
I had a similar problem with Optrix Video Pro but was finally able to get it to record. I get my Dual gps tomorrow but wanted to get this set up . Any suggestions would be great as I head off to a race tomorrow.
Re: Set up Help
GPS Update Rate in red means you have no GPS reception. Walk outside and it will go away - same for accuracy. In case you use an iPod5 without external GPS, you have no GPS at all and you can't use it. Other than iPhones or iPads with 3D option, iPods and standard iPads do not have a GPS sensor on board.
Nearby Track in red means there is no loaded track set nearby. This will go away once you are on track.
