adjust sync points in android
arsprod
Post by arsprod »
I'm using more gopro vids to sync to laptimer and pleased that it works so well (and will upgrade to Grand Prix as soon as it's available). Setting sync times in android is a pain though especially on a phone. The little slider it way too sensitive and the "+" and "-" buttons only move a tenth at a time so it can take forever to set the right spot. Add to that a slip of the finger can jump minutes and it can be a frustrating experience. I don't see a way to type in the sync point numbers - am I missing that or might that be an upcoming feature? Thanks
Re: adjust sync points in android
No, you don't miss anything here. I plan to add some more scrolling support in the next major release.
arsprod
Post by arsprod »
Harry wrote:No, you don't miss anything here. I plan to add some more scrolling support in the next major release.
Excellent - if it's just as easy numeric input would be REALLY nice! thanks Harry
arsprod
Post by arsprod »
Harry, did I miss something or is this still not in? If nothing else, make the (-) and (+) signs able to push and hold so the time goes down or up fast. As it is one must tap 100 times for each second. It's maddening!
Next major release will be 20 ;-) It is not yet available, sorry.
arsprod
Post by arsprod »
Ah, I missed that key word "major"
Tem120
Post by Tem120 »
hello this is kind of relevant , when ever I use Full HD on my phone to record , when i do the overlay data is slow compared to the video how do I adjust it so that it syncs up correctly ?
Sync point adjustment like discussed here should be necessary for manual video addition only. In case data / video are out of sync for LapTimer recorded footage, please adjust Overlay Synchronization / Video in LapTimer's Expert Settings.
In case data is late (i.e. video ahead), please decrease the value by e.g. 0.5s.
