Notifications leading nowhere in App
I received some notifications in HLT the last few days, most of them being challenges on nearby tracks but also one with the update "change log". That one seemed to be somewhat longer and was cut off somewhere and swiping it in fact opened the App but simply in Timer view and I couldn't find the whole message anywhere. Am I missing something or are longer messages simply not "supported"?
Re: Notifications leading nowhere in App
Longer messages are supported using a separate dialog within LapTimer. Next time you receive a notification, please goto the notification center (swipe from top to bottom in iOS) and touch the LapTimer notification. This should actually work. There are several issues nevertheless. Especially when LapTimer is started regularly (i.e. not by touching a notification) all "open" notifications are purged and not accessible any more. Your case should actually work as it is handled the same way as touching a notification in notification center... I will work on this item again anyway, I will check that too.
Update: the last LapTimer version has introduced in issue for notification displays: the notification message view within LapTimer is not opened when selecting a notification from notification center. As 18.3.5 is in Apple's review queue already, this will be fixed in 18.3.6...
