Master & MultiCam Usage
llan981
Post by llan981 »
Is this possible? I am in process of buying iPhone 6 with 128GB and use it at 1080P 30FPS behind my front seats. And I have another IPhone on the windscreen so I can see the lap data.
But my problem I would like lap data and ICLOUD to flow to the multicam. Is there a simple solution?
Re: Master & MultiCam Usage
The Multicam App is a remote video tool for HLT. Apart from not being possible to send videos from HLT to Multicam via iCloud it is also useless since Multicam can't process the GPS lap data or do any overlaying.
Btw. Multicam will not work on iOS 8 at the moment so you have to use something with iOS 7 or lower.
Consider using the 6 in the screen with LapTimer and the MultiCam app on you second phone in the back. Once both videos are available on the 6, swap the order to make the rear cam the master.
