Unlisted Course - Pocono Int'l Raceway SouthEast Course
llan981
Post by llan981 »
I looked at your database there is not a configuration listed for the Pocono SOUTHEAST COURSE. What to do? The file is attached and the course is outlined in yellow.
Pocono SouthEast.jpg (241.03 KiB) Viewed 8145 times
Re: Unlisted Course - Pocono Int'l Raceway SouthEast Course
[Moved to Tracks forum]
Monika will take care for this and come back soon.
Monika
Post by Monika »
Hi, to add it I need the position of start/finish - at least roughly marked on the picture above.
- Monika
llan981
Post by llan981 »
What I was told, going to try to pit in/out on the access road that's part of east in the middle of the picture (grey pit road below yellow line). Also, we will not be running the hairpin highlighted in east - we will just run the grey curved road instead and skip the hairpin.
So with the above info above, the pit-in/out is the grey line below the below the yellow going in the paddock. The start/stop typically is in the center of that straight. Next per the note above, I read that to mean the hairpin on the left side of pic near middle will not be used.
Monika
Post by Monika »
Thanks.
Pocono Raceway, SouthEast is now available for download, there is a clockwise and a counter clockwise configuration.
- Monika
llan981
Post by llan981 »
I just got from the staff at Pocono the following graphic and they said course can be run clockwise or counter-clockwise but most run it CLOCKWISE
Pocono SouthEast2.jpg (217.66 KiB) Viewed 8118 times
llan981
Post by llan981 »
I want to thank Harry's lap timer in creating this track 2 days before a track event when I noticed this specific configuration was not in the database. I NEVER say an organization so responsive to customer requests. Well Done!!
llan981
Post by llan981 »
How do you download track? I did a full reload and reloading add on list from server but tracks do not show up on list. How do I refresh?
Please refresh the list again. We just tried it with LapTimer v18.3.0 and it worked fine.
llan981
Post by llan981 »
The grey graphic from the staff at Pocono Raceway show the start/finish. Does that change anything based on what you seen in the early graphics I sent the other day? Also, since I will be at the track this weekend, is there any detail, I can send you to better provide on exact datapoints and turn names? I am using HLT GP with a Dual XGS160.
