Throttle bar dont work
PitrsRS
Post by PitrsRS »
Hi, I discover a little problem. I have DSG transmission, OBD ELM327 BT. When I look at actual Throttle position it´s a little bit weird, It´s allways on full and dont fall down
Here is test video on local airfield
http://youtu.be/gJNVtCWU4zo?t=50s
when I slow down and start braking, throttle is sill on max and dont fall down.
2016 SEAT Leon CUPRA 290 ST
Re: Throttle bar dont work
Probably some unexpected throttle data delivered by the dongle or the car. Please follow the instructions in the thread below to log a sample of throttle data delivered: viewtopic.php?f=20&t=1500
Please make sure you have the full throttle range recorded, so one "full throttle" situation is required.
