INTERNATIONAAL KART CIRCUIT GENK BELGIUM
WESVIC
Post by WESVIC »
IS THIS TRACK IN HARRYS LAPTIMER
No, not yet. Please post some links and information here and we can add it. As kart tracks are mostly not well described on the net, a short description like those you find for other tracks would be useful too.
WESVIC
Re: INTERNATIONAAL KART CIRCUIT GENK BELGIUM
Post by WESVIC »
Harry wrote:No, not yet. Please post some links and information here and we can add it. As kart tracks are mostly not well described on the net, a short description like those you find for other tracks would be useful too.
here are é circuits where iam ryding mutch
genk belgie http://www.kartinggenk.be/nl/circuit_intro.aspx
eindhoven belgie http://www.outdoorkarting.nl/circuit/
WESVIC
Post by WESVIC »
i ride sundag at genk when i buy donwload the roofir version can i log the circuit ?
WESVIC
Post by WESVIC »
i mean the rooky version to start with
Yes, you can use the assistant included to setup the track. Take care to not put the phone into your cloth and use a mount instead. That's a frequent issue (bad GPS reception) for kart drivers.
WESVIC
Post by WESVIC »
Harry wrote:Yes, you can use the assistant included to setup the track. Take care to not put the phone into your cloth and use a mount instead. That's a frequent issue (bad GPS reception) for kart drivers.
i put it in a waterrisistend bag en tape it on my steeringwheel do you have ideas for a goud mount end waterproof because in kart it shakes hard
Depends on the device, for iPhones, Optrix cases are great.
WESVIC
Post by WESVIC »
Harry wrote:Depends on the device, for iPhones, Optrix cases are great.
iPhone 5 S
Monika
Post by Monika »
The Genk CIK-FIA circuit is now available for download:
Check it out via 'add-ons', 'Update' list via the button at the right top, search for the track e.g. via 'Genk' and download the new track.
Eindhoven circuit: I'm missing a circuit layout (the homepage just states 'Circuit gesloten voor vrije training'). Is it still an active track?
If so and someone posts/links the layout and the GPS coordinates of the start/finish line I can add it to the database too.
Monika
