BT Connectivity Still Not Working after iOS 7.1.2
Michael_R
Post by Michael_R »
I'm still having the same issue with the BT1 dropping down to 0Hz then back to 5Hz, back and forth intermittently. I'm using the BT1 with a Dual XGPS160, but even with the GPS disconnected the BT1 still has the same issue. I followed the suggestion of connecting the GPS first, then powering up the BT1 while LapTimer is running successfully at 10Hz on the XGPS160. The GPS stays running at 10Hz fine, but the BT1 continues its intermittent connectivity.
I have gone so far as to completely reinstall iOS 7.1.2 via iTunes from a clean iPhone 5s, but still no luck. Any suggestions?
Re: BT Connectivity Still Not Working after iOS 7.1.2
This is not the iOS7.1.2 issue but a problem with the OBD dialog. Please check the Debugging OBD connections in the Accessories/OBD forum and send a log to Harry@gps-laptimer.de
