Purging a circuit
yowie282
Purging a circuit
Post by yowie282 »
How do you purge/deactivate an active circuit on an Android phone using Harry's lap timer "Rookie"?
Re: Purging a circuit
To purge a track set, long-press the row right below the track header in Lap List. In the action menu shown, you will find a bin to delete the track set. In case no laps have been recorded yet, the track is completely removed.
yowie282
Post by yowie282 »
I inadvertently made some tracks "active". I want to change this back to "load". My phone will now not load any more tracks so i figure the tracks i have activated have overloaded it's system.
The tracks are shown "Active" as long as they are in Lap List. Removing them from this list, will remove the active state from the Tracks / Add-ons list too. In case you see tracks in Lap List with the section header only, please use the "Manage List" function in the bottom of the list to remove them. The overall number of tracks you can have in Lap List at the same time is 16 (for historic reasons).
