COPY FEATURE FOR CAR LIST.
MX5RACER
Post by MX5RACER »
Is there a way to copy the information from one car to create a new one? If I want to share my car with someone else, the easiest way to track which driver is driving is to create two cars and switch between them when the drivers change, right? If that is the case, when you go to create a new car, you have to start from scratch and change all the fields which can be time consuming, especially at the track. If there was a way to create a new copy of an existing car and then change the name, that would make things much easier and quicker.
Re: COPY FEATURE FOR CAR LIST.
Currently, there is no function like this. As the import / export is limited to car type and name, this does not add a lot of value either.
I add a Duplicate Vehicle function to my list.
