OBD sensor not receiving data at expected rate.
Posted: Fri Jul 11, 2014 11:12 pm
by froggy47
Or words close to that. I tried 4 different OBD sensors & this one "seemed" to work best, but today I got the yellow warning, should I buy a few more? Seems like a total crap shoot to find one that HLT will work with. This for Motox X phone/android.
Thanks if anyone can help with a specific brand/vendor that works. I did read the OBD help, but it wasn't much (help).
Is it ok to run this setup with the OBD in the yellow?
Re: OBD sensor not receiving data at expected rate.
Posted: Sat Jul 12, 2014 7:32 am
As long as the rate is not zero, communication is probably working. Update rates are depending a bit on the dongle, but mostly on your car's bus. Which brand / model / year is it?
Posted: Sat Jul 12, 2014 6:49 pm
by froggy47
Harry wrote:As long as the rate is not zero, communication is probably working. Update rates are depending a bit on the dongle, but mostly on your car's bus. Which brand / model / year is it?
2004 Chevrolet Corvette z06.
Posted: Sat Jul 12, 2014 8:57 pm
It seems the CAN bus has been introduced for 2005 Z06 models, so your 2005 Z06 runs one of the slower protocols. However, you should be able to get 2 Hz with most dongles, not below. Can you please describe of the OBD regularly disconnects (i.e. drops to 0 Hz) and raises again? Please feel free to send a trace log to me for analysis:
http://www.laptimer-forum.de/viewtopic.php?f=20&t=1500
Posted: Sat Jul 12, 2014 10:18 pm
by froggy47
Harry wrote:It seems the CAN bus has been introduced for 2005 Z06 models, so your 2005 Z06 runs one of the slower protocols. However, you should be able to get 2 Hz with most dongles, not below. Can you please describe of the OBD regularly disconnects (i.e. drops to 0 Hz) and raises again? Please feel free to send a trace log to me for analysis:
I tested yesterday, laid out an approximate 60 sec "autox" course, which was just streets in my neighborhood. Ran 3 laps & working ok except for yellow obd warning and the "hard brake required" warning. Took some time in between runs as would be similar to real event. Seemed good all 3 could be overlayed & had data.
It could be that my problem is remembering all the various battery saver interruptions that I have to shut off before using HLT.
Battery saver mode
Screen security lock timer
These are the main two, I don't know what to expect if a call comes in when I am recording a lap?
Thanks for your patient help.
Posted: Sat Jul 12, 2014 11:49 pm
Calls will interrupt LapTimer operation. For serious laps, I recommend to forward them to your box. Despite slow car busses, drops in connection due to compatibility issues and disturbing other wireless connections are the usual reasons for low rates.
