Video did not record.
jstan15
Post by jstan15 »
I just got done running an event and none of the sessions were recorded.
This is the first time at this track (Thompson Speedway).
I have not had any problems with video recording in the past (NHMS or Limerock).
I have an Iphone4s.
I tried removing all the tracks and just installing the Thompson track, but that did not work.
I was staging about 10 minutes before each session started.
Could the long delay before crossing the start/stop to trigger the video be the root cause?
Please let me know if I some how disabled an option for video recordings.
Jason
Re: Video did not record.
No, the delay has not impact on video recording. Question is if only video is missing, or if no laps have been recorded either. In case it is the later, please check viewtopic.php?f=8&t=2 for possible reasons LapTimer didn't trigger. The track set itself delivers laps (check Hall of Fame), so the track set seems to work and it is probably about the GPS accuracy. In case it recorded laps but no video, I'd assume either memory has been short (you should see a warning in this case), or video recording has simply not been enabled.
jstan15
Post by jstan15 »
Harry wrote:No, the delay has not impact on video recording. Question is if only video is missing, or if no laps have been recorded either. In case it is the later, please check viewtopic.php?f=8&t=2 for possible reasons LapTimer didn't trigger. The track set itself delivers laps (check Hall of Fame), so the track set seems to work and it is probably about the GPS accuracy. In case it recorded laps but no video, I'd assume either memory has been short (you should see a warning in this case), or video recording has simply not been enabled.
Ah thanks...The background video was disabled.
