Dominant Audio track using multi cam
llan981
Post by llan981 »
Can you select which master/multicam is the audio track used in the overlay? I have a front master windscreen camera but would prefer the audio coming from the rear facing go pro located on the tow hook.
Other note: When will the HLT Desktop version be released MAC, WIN or both?
Re: Dominant Audio track using multi cam
LapTimer always uses the master video's audio track. To change that, you need to mix in another audio track to the video using some video editors. I have that item on the feature request list already.
The Desktop version will be MAC and is planned for next year.
Dubbedown
Post by Dubbedown »
Harry wrote:LapTimer always uses the master video's audio track. To change that, you need to mix in another audio track to the video using some video editors. I have that item on the feature request list already.
What about in a situation where you use iPhone as main but later remove iPhone video and use GoPro as main during the overlay process? Will it then take audio off the GoPro correct?
Yes.
