HLT with VboxSport/Gopro3+/OBD
Posted: Fri Jun 13, 2014 6:58 pm
by jjustitz
I am using iphone 5 with a gopro 3+ black edition and vbox sport .. well trying to ..
I managed to connect the vboxsport, and the gopro .. but now I want to add an OBD .. where can I add this?
Thank you in advance.
Jerome
Re: HLT with VboxSport/Gopro3+/OBD
Posted: Fri Jun 13, 2014 7:06 pm
Please check www.gps-laptimer.de/Compatibility.html for available options. You will need to wait for availability of either the OBDLink MX wifi (because it is the only wifi dongle that can be combined with the GoPro wifi), or the BT1. I recommend the later as you configuration is already complex and BT is easier to handle here.
Posted: Sat Jun 14, 2014 4:17 pm
by gplracerx
Assuming that Apple ever fixes their BT issues with iOS 7.1.x. If you haven't upgraded to 7.1, don't. 7.0.6 works reasonably well. 7.1.0 and 7.1.1 will drop multiple BT connections frequently.
