Page 1 of 2
G's backwards
Posted: Fri May 30, 2014 10:57 am
by xps911
[youtube]
http://www.youtube.com/watch?v=5Rk4R99JoGY[/youtube]
in the above video, if you look at the G's they seem to be going front when should be going back?
Re: G's backwards
Posted: Fri May 30, 2014 11:15 am
by xps911
correct link now
Re: G's backwards
Posted: Fri May 30, 2014 11:17 am
In which orientation did you have the phone? Has it been mounted in the wind screen? Although this can be fixed easily (by applying the correct interpretation
), it should indeed show longitudinal acceleration the other way around...
Re: G's backwards
Posted: Fri May 30, 2014 11:20 am
by xps911
mounted on windscreen, the charging socket was facing the left of the car (if sitting in it)
Re: G's backwards
And you used the front or back cam?
Re: G's backwards
Posted: Fri May 30, 2014 11:30 am
by xps911
front camera
Re: G's backwards
Posted: Fri May 30, 2014 11:37 am
I tested this a minute ago and actually it worked as expected. Maybe you changed orientation of the device after calibration has been done already... Without a log, it will be difficult to understand what exactly happened. Please just check if you can reproduce it and let me know.
Re: G's backwards
Posted: Mon Jun 02, 2014 9:24 am
by xps911
Ok I replicated what happened. I had the phone already horizontal, but with the charger port on the left, i quickly turned it around, so the charger point was on the right, and it didnt ask for recalib
Re: G's backwards
Posted: Mon Jun 02, 2014 4:48 pm
by gplracerx
xps911,
You can fix that, but it will take a while. On the traction circle chart page there are buttons to rotate the data in case the yaw calibration was off. The problem is that each button press only rotates by two degrees. If it's off by 180 degrees, you will need 90 steps. Also, for me, it doesn't always rotate when I tap the button, so it would take even longer. Oh, and you have to adjust each lap separately.
Re: G's backwards
Posted: Mon Jun 09, 2014 1:28 pm
by xps911
gplracerx wrote:xps911,
where do you go to do that ?
