Updating track choice after the run
pk47tech
Post by pk47tech »
I ran an event this week where I used the wrong track configuration (previously had run Mid-Ohio w/o chicane, and this week was with the chicane).
Is there a method to tell the software the laps were run on the other track configuration now? Even if it's a manual method of exporting and reimporting data that would be fine.
Thank you.
--Jim
Re: Updating track choice after the run
Load the correct configuration using Load Track. Allow LapTimer to purge the existing track set (this will delete the track set only, not laps). Select each of the laps you recorded from Lap List and change the Track row to the correct track set.
