XGPS150A update rate
Posted: Sat May 17, 2014 3:49 pm
I'm using a fully charged XGPS150A with the latest firmware (1.2.6) and the connection doesn't seem as reliable as it was a year ago before the 5hz capability was added. Lately, whenever I have an issue with HLT, if I simply turn off the XGPS150A, things start working. When I am having a problem, the System Status usually shows that the Update Rate is 0, then I have to turn off and on either Bluetooth or the XGPS or both to get it working at 5hz. And when the XGPS is working, it doesn't mean it will remain working throughout the session.
Is there anything I can do to improve the reliability?
Deven
Deven
