Android Synchronization issues
Posted: Sun Apr 06, 2014 4:00 am
I'm more confused after reading threads on here so I'm creating one for my problem. I'm using Galaxy s3 running android 4.3. I'm using Qstarz 818xt external Bluetooth at 10hz and for ODB I'm using an odblink mx that HLT reports running about 10hz.
this is a short video of where I stand now in my configuration:
ODB 1.5s
GPS 1.5s
Accelerometer 1.5s
https://www.youtube.com/watch?v=J9F4s8TVG10
using the default sensor delays of 1.5 for gps and 1.0 for ODB and .5 for accelerometer my data cannot be synced properly to dashmaster at all. The RPM shift points are about a half second off. I'm gotten the shift matching the sound on my recordings for the shift to what looks almost correct using 1.5s for ODB sensor delay but my real confusion lies in that my ODB is 10hz, shouldn't I be decreasing the value but decreasing the value puts it out of synch even worse so with it now at 1.5s for ODB it's at least pretty damn close but its confusing, If I move it down to .5 the difference between the sound of my car shifting and the rpm guage showing the shift is like 2 seconds. doesn't make sense to me. Should be adjust this value up or down to further refine the ODB?
Secondly, the accelerometer I set to match the other two, I notice when braking almost stopped the lineal decal is still relatively high even though stopped so I need to drop this down to the default of .5, I think that was the default for the accelerometer and while on that topic does HTL use the ACCELEROMETER from the phone or from the GPS position and calculate the value?
Lastly the GPS sensor delay? The Gforces for Lineal and lateral are coming from the accelerometer I presume so I presume I should probably just leave this at the default of 1.5.
I can live with other pieces not being perfect at this point but this really frustrates me. The same behavior is exhibited in dashware as well as racerender.
if anyone can suggest what to change and whether increase or decreasing a value based on the video linked in this message you have my gratitude. Thanks
BoomSpoon
ODB 1.5s
GPS 1.5s
Accelerometer 1.5s
BoomSpoon
