Model:
Is data consistent and undelayed when displayed on a device?
I ask as most the videos I have seen the data is not sync'd in time with the video/sound.
I wonder where the sync error happens? Slow Bt data,slow device display or app failing to sync?
What are you using?
- 20 or more Posts ★★★
Re: What are you using?
Sensors (GPS, acceleration, OBD) and video do not come with a common time stamp. This means LapTimer needs to align all these inputs based on what it knows about the sensor and some heuristics. The standard setting will give a good result for most users. For non standard sensor configurations, or if one wants to improve timing, the sensor specific delay between time a event occurs in reality, and the time the data is received by LapTimer can be configured in LapTimer's Expert Settings. Please note this is a complex topic and changing the delay will often degrade quality instead of the opposite. Search the forum here for "sensor delay" and you will find plenty of discussions and explanations.
Cheers for reply
