OBD Update Rates with KiwiWifi
The OBD update rate varies a lot by car connected to. LapTimer is optimized to get the best possible update rate for RPM and Throttle position. All other values are retrieved at lower update rates to get the best for RPM / Throttle. This is what I have seen so far:
2005 Porsche 911 C2 1.4Hz
2011 Porsche 911 GTS 7.0Hz
2007 Volvo C30 2.0d 6.0Hz
Please let me know what you have seen.
-------------- Full list collected from thread --------------
2006 Audi RS4 B7 (V8) - 8.4 Hz
2010 Audi TT RS - 8.1 Hz
2001 BMW 325Ci - 1.3 Hz
2007 BMW M Coupe - 1.5 Hz
2011 BMW 335i - 8.0 Hz
2009 Chevrolet Corvette - 8.0 Hz
2011 Ford GT500 - 5.5-6.0 Hz
2003 Honda S2000 - 1.5 Hz
2008 Honda S2000 - 10.0 Hz
2005 Lotus Elise - 2.0 Hz
2008 Mitsubishi Evolution X - 3.0 Hz
2010 Nissan GTR - 3.5 Hz
2003 Porsche C4S - 1.6 Hz
2005 Porsche 911 C2 - 1.4 Hz
2008 Porsche 911 Carrera S - 1.6 Hz
2008 Porsche 911 Turbo - 7 Hz
2011 Porsche Boxster Spyder - 3.0 Hz
2011 Porsche 911 GTS - 7.0 Hz (10-11Hz with OBDLink)
2005 Renault Clio Sport - 0.8 Hz
2006 Renault Clio C - 10.0 Hz
2007 Volvo C30 2.0d - 6.0 Hz
2008 VW Polo 1.9 TDi - 1.4 Hz
infinity
Post by infinity »
2006 Renault Clio C 10Hz
2011 BMW 335i 8Hz
1995 Porsche 993 - has OBD, but cant get any information with the Kiwi Wifi
sylvain007
Re: OBD Update Rates with KiwiWifi
Post by sylvain007 »
2005 Lotus Elise - 2.0Hz
For information, I miss a very key information from the ODB: the water temperature. I get it from Fuzzycar or Rev (full version), but not from Harry. If I could get it, I will not need Rev anymore!
Thanks for the feedback. On the temperature: o.k., I'll put this on my list.
sylvain007 wrote: For information, I miss a very key information from the ODB: the water temperature. I get it from Fuzzycar or Rev (full version), but not from Harry. If I could get it, I will not need Rev anymore!
Added both coolant and oil temperature (if available) to the upcoming version 13.3.
spencers
Post by spencers »
2001 BMW 325Ci - 1.3hz
sylvain007
Great! Looking forward for it! I will give you my feedbacks once it will be available. Can't wait to test this... It will be so useful for me :mrgreen:
kingfish
Post by kingfish »
2009 corvette - 8hz
random1
Post by random1 »
Is there any way to cut down the variable to just TPS and Tach and possibly achieve a higher rate? Being able to select OBDII variables in preferences would be nice assuming cutting down helps with the update rate. Thanks.
Rob Rockefeller
2003 Honda S2000
SCCA Solo - STR
LapTimer requests RPM, TPS, and VSS only at high update rates. MAF is requested every 4th time, all others every 16th time.
I did some experiments with an a selective approach but did not get significant better results as long as we take RPM, TPS, VSS as a minimum.
