Non-Track Use?
Posted: Sun Jan 12, 2014 3:42 am
by Grussgott
Hi All,
I'm hoping one of you can help - I've tried combing through the forum but am still not sure on my use-case ... here's what I'm wondering if laptimer can do:
* Non-track use; I drive a lot of canyon roads and would love to create overlayed videos of the drive
* Android
* Overlayed on a gopro (black series)
Can laptimer do this? If so, which version? Will the March 2014 build work for this?
thanks so much for the help!
Re: Non-Track Use?
Posted: Sun Jan 12, 2014 11:28 pm
You can start LapTimer manually if you want. To turn manual Go / Stop everywhere (not only in the Video and Classic Stopwatch views), select "Manual Timing" in LapTimer's "Settings". To overlay a GoPro, you need to transfer the video to your iPhone. Please check the video documentation for the details: http://www.gps-laptimer.com/LapTimerDoc ... hapter.pdf Finally, you need Petrolhead or GrandPrix edition available for iOS only currently. I plan to release LapTimer Petrolhead for Android in March, existing Rookie licenses will get an upgrade path.
