Autox mode
Josh7owens
Autox mode
Post by Josh7owens »
When are you going to make a autox mode?
For example video/data starts when you launch the car using a set "g" such at .3 or somthing. Then have the data stop when the car stops moving.
Alot of us autocrossers are buying this app and I hate hitting start/stop before and after a run. The auto start and stop feature only works 60% of the time and I'm using a external gps. I can't risk losing 2/6 of my runs because of malfunctions so I have to manually start and stop it.
Re: Autox mode
Full autocross support will be included in v14. Please search for 'beta' here in the forum.
Josh7owens
Re: Autox mode
thanks harry! I looked it up and joined the bata testing list. I have 7 races between now and the end of Aug so I should be able to do alot of autocross testing.
