Calibration for motor bikes....????
Timmy74
Post by Timmy74 »
Hi Guys,
All i want to do is mount my iphone with Emprum GPS and "Harrys Lap Timer" on my bike and GO!! I can not seem to do this because as soon as the bike leans over for a corner the "Conformation: Your displays orientation has benn changed... Blah Blah, Blah!!!
Would there be a forum or a good "Motorcyle Track Day" set up somewhere that i can follow here at Harry's GPS suite forum, so i can make it work hassle free please?
Kind regards.
Tim...
Re: Calibration for motor bikes....????
Strange... Because of the lean angle, the iPhone should actually never detect a rotation at all on motorbikes! Please give me some more information:
  • How have you mounted the device so far or does this happen when testing LapTimer and rotating it in your hands?
  • LapTimer blocks any rotation when driving faster than 20km/h (can even be adjusted in Expert Settings in case this is not what one wants).
  • Do you run the latest LapTimer version (17.5.4)?
P.S. Please check this video for a perfect Emprum/iPhone/motorbike mounting position: https://www.youtube.com/watch?v=Nr8spECUAWU
Timmy74
Post by Timmy74 »
Hello Harry,
Thank for your reply. I may have jumped the gun a bit!? Sorry.... After downloading and installing the latest release and obtaining my Emprum GPS, I tried it out by just holding it and seeing the "rotation" error and just assumed something was not right.
I could not find anywhere that, that feature would disable once it goes over 20km/h...?
I have a track day coming up and will give it all a go! I will get back to you if there are any problems.
Again sorry for my confusion and thank you for the youtube link too. Very helpful.
Kind regards.
Tim...
The setting is one of the Expert Settings, they are for support cases only. You do not need to change anything here...
Otherwise no problem, this forum is for questions :-) Moved the thread to "Using LapTimer".
