Data erased
Posted: Mon Nov 18, 2013 2:22 pm
by bresemo
I encountered a small problem with Harry's LapTimer ROOKIE Android Edition.
On a Galaxy S4 Android 4.3, I did a wipe data / factory reset, but unfortunately, this action completely erased all data Harry's LapTimer recorded.
I looked then, in what directory the data is stored, but I have not found.
I think the solution would be to configure LapTimer, so that saves data in a separate directory, this would prevent the data from being erased.
Thank you very much for your work.
Best regards.
Bresemo
Re: Data erased
Posted: Mon Nov 18, 2013 11:42 pm
LapTimer stores data in its data area (which is deleted when the app is deleted). In case you want to wipe your phone, please run an export of all laps to .hlptrl - which is available in Lap List. This export can be restored later.
