Hi guys.
I've always used Harry's Lap Timer with my Iphone 4s (and his gps); now I've bought a GoPro Hero 3+ Black.
I'd like to make videos with GoPro, and make lap timers (without video) with the iPhone (I have no too much free memory in it so it's better without video).
2 questions:
- How can I paste GoPro's video and Harry's Lap Time timing and performances?
- How can I improve the precision of the Iphone's gps? Can you reccomend me an external gps?
Thanks.
No video + GoPro?
Re: No video + GoPro?
The GoPro integration is documented here: http://www.gps-laptimer.com/LapTimerDoc ... hapter.pdf Please note that although you can turn off the video view starting with 17.5 while controlling a HERO recording in background, you will still have the iPhone cam recording in background too. Please select a low resolution in LapTimer's Settings in this case - this saves memory and battery.
There are several great external GPSes available. Please check http://www.gps-laptimer.de/Compatibility.html for the full list. The recommended solutions are fully integrated with LapTimer and increase timing accuracy to the best you can get from GPS based systems.
Thank you very much!
Ops, I had "best available - high resolution", now I'll set "192x144 - Low"Harry wrote:Please select a low resolution in LapTimer's Settings in this case - this saves memory and battery.
And compression GPS now is "low", is it ok o I have to change it?
Thanks.
GPS compression has nearly no influence on space and should be turned off completely for recent versions.
When I go to LapTimer - settings - multicam control - discover multicams - and try to set it as ON, I have this warning "this feature is not available in this app edition" but I have the latest (v17.5.1).
That's not on the version, but the LapTimer edition. MultiCam is a LapTimer Grand Prix feature which your version can be upgraded to (Add-Ons).
Ah ok, is the Grand Prix Upgrade to buy at 8,99 in App store? Thanks.
The upgrades are available from within your LapTimer: select the Add-ons tab and you should see the "Grand Prix Upgrade" (in case you run a Petrolhead Edition currently).
