Extract Track from existing data
tokyopav
Post by tokyopav »
I recorded a track with the manual start stop and really want to extract a track from the data. I know where the start and finish are with the overlaid video. Is there any way to extract a new track from the data.
Pav
Re: Extract Track from existing data
That's actually not easy from within LapTimer as the data recording's GPS positions are not displayed. In case you know the first GPS position you recorded for a manual lap is the correct trigger position, just export that lap to .csv or .hlptrl Next, open that file and note the latitude and longitude values you see for the first fix (you will see them in pur decimal degree, e.g. 26.21361562). Within LapTimer, select decimal polar coordinate format in Settings. Create a trigger in any position and open the details. Edit both latitude and longitude to match the coordinates you took notes of above. Please check the position is valid by displaying in on the Map (there is a button in the bottom of POI Details).
tokyopav
Post by tokyopav »
Harry wrote:That's actually not easy from within LapTimer as the data recording's GPS positions are not displayed. In case you know the first GPS position you recorded for a manual lap is the correct trigger position, just export that lap to .csv or .hlptrl Next, open that file and note the latitude and longitude values you see for the first fix (you will see them in pur decimal degree, e.g. 26.21361562). Within LapTimer, select decimal polar coordinate format in Settings. Create a trigger in any position and open the details. Edit both latitude and longitude to match the coordinates you took notes of above. Please check the position is valid by displaying in on the Map (there is a button in the bottom of POI Details).
Great, I'll give that a try.
cheers
