iPhone 5S
Posted: Sun Oct 06, 2013 7:01 pm
by tulloch
Is there anything in the new iPhone 5S hardware that could be of benefit to Lap Timer?
Re: iPhone 5S
Posted: Sun Oct 06, 2013 10:10 pm
In the beginning it will be higher speed and most probably better battery time. Over time, LapTimer will most probably use additional features from the new M7 motion chip.
Re: iPhone 5S
Posted: Fri Oct 11, 2013 2:35 am
by Dr_Pippin
And hopefully 64-bit processing down the line, too.
Re: iPhone 5S
Posted: Tue Nov 05, 2013 12:49 am
by Blitz05
The 5S offers a 34 Hz on the accelerometer where as the predecessor iPhones maxed out at about 29 Hz. Only thing that comes to mind is more accurate data logging?
Re: iPhone 5S
Posted: Tue Nov 05, 2013 9:45 am
by bulls23
Blitz05 wrote:The 5S offers a 34 Hz on the accelerometer where as the predecessor iPhones maxed out at about 29 Hz. Only thing that comes to mind is more accurate data logging?
Take a look at the expert settings, there you can change the update rate of the accelerometer and push it up to 100Hz. Don't know where the hardware limitations are though.
