ios7 bug ?
xps911
ios7 bug ?
Post by xps911 »
When you are in the app, and slide the finger from the bottom up to go to the control center, when it goes back to harrys laptimer, it shows the harrys gps suite wallpaper for 15 seconds.
Re: ios7 bug ?
What happens next? Just tested it using an iPhone5 + LT 17.4 + iOS7 and it behaves as expected (i.e. CC is coming up, LT shows wallpaper, I slide CC down, wallpaper is replaced by LT view again).
xps911
Re: ios7 bug ?
Post by xps911 »
it goes back, but as i said takes at least 15 seconds after i've slide down for the wallpaper to go, and the app to show again
Re: ios7 bug ?
I assume you have the latest LT installed? Is your LapTimer is slow in general? Maybe just restart your phone and try again.
Re: ios7 bug ?
I can confirm that behavior on an iPhone 4 running iOS7 and the latest HLT. I made a small video and send it to you Harry.
xps911
Re: ios7 bug ?
Post by xps911 »
on latest version, and i'm using an iphone 4 also.
I can try it on a 4s later if you want ?
Re: ios7 bug ?
@bulls, thanks for sending. As the iPhone5 comes back instantaneously, I doubt it is purely processing specific. On my 5, it is clearly sub second. Maybe you try cleaning up main memory and try again. That is just a guess, might be something else too (e.g. network availability etc). At least that gives you sufficient time to watch the great splash screen graphics :-D
elriclaurie
Re: ios7 bug ?
Post by elriclaurie »
just bought LT today. tried the +new autocross few times. after the first run which set the start and goal. when i back to the start position its just crashed after i accelerate .. ..
running a iphone 5 ios7.
Re: ios7 bug ?
Sorry to hear. Please be so kind and send the crash logs generated, here is the how-to: viewtopic.php?f=8&t=1115
xps911
Re: ios7 bug ?
Post by xps911 »
Doesn't do this on a 4s (don't even see the wallpaper), only on the 4
