Bad Elf 2200 GPS Pro
Shuasha
Post by Shuasha »
Will this work with Harry's Laptimer effectively? I know the other Bad Elf products don't work due to the lack of API, do the bluetooth based ones have the same limitation?
I looked at the Dual X160, but it has horrible reviews in the USA.
Re: Bad Elf 2200 GPS Pro
Same issues with this BadElf, not recommended. Please check the XGPS160 thread here on the forum, that adds some insights.
I've just posted a 5 star review of the XGPS160 on Amazon US. When there aren't many reviews, you have to treat all of them as somewhat suspect.
Dreadlezz
Post by Dreadlezz »
Just wondering if the Bad Elf Pro GPS is still not supported. The reason I'm asking is that LapTimer is listed as a supported application.
LapTimer supports any GPS that feeds location information into iOS's location service. So they are right in terms of compatibility = "works with". However, it is not LapTimer supported - which means besides the higher update rate, additional timing accuracy and extra information like satellites is not available. This is the reason it is not recommended and other options should be preferred from a LapTimer perspective.
Dreadlezz
Post by Dreadlezz »
Thanks for the quick response and clarification Harry! Just placed an order for the Dual XGPS160.
