ease for track selection
xerskine
Post by xerskine »
Harry, It would be a great help and time saver if you could check the GPS coordinates of the phone to help select the desired track. Currently, the user is faced with a long list of tracks around the globe and has to scroll and select from all available tracks. Considering the GPS is always running with HLT and the track coordinates are available for all tracks, could you limit the track selection the tracks that are nearest the user? Or would it be possible to have a selection "Use Coordinates" or "Select From List" in order to streamline the track selection.
I mentioned this to several HLT users and they all agreed that this would be a welcomed feature.
Great product none the less!! After using t i-version for a couple of years, I just downloaded and installed the Android app. I can't wait for the petrolhead version on Google!
Re: ease for track selection
Not yet implemented but planned for v17.5! Till then, just use the full text search filter. In case you are in Texas, enter "Texas", in case you are in Germany, enter "Germany". LapTimer's full text search will reduce the tracks shown to those matching the search term.
P.S. The filter is available in the top of the "Tracks" list.
