what does the "No Fix" message mean and how to you fix it?
Posted: Sun Sep 01, 2013 4:05 am
Hi there. I am using HLT Pro on an iPod touch with a Bad Elf GPS connected to the 30 pin connector on the iPod Touch.. I was tested the set up in my neighborhood, and was able to record GPS and video using the iPod Touch and a GoPro successfully. I took this set up to Summit Point race track, and when I try to Start recording my lap, I see "No Fix" next to the GPS signal icon. What does this mean, and how do I fix it?
As a side note, this location does not have good Wifi signal. I was able to find a location outside the track where I could get Wifi. I connected to that WiFi and was able to gt GPS signal. But when I tested in my neighborhood, I did not have any Wifi signal either.
Do you need to have Wifi connected to get the initial lock on GPS? Once you get the lock, can you disconnect the Wifi connection? I am hoping to get some data logging done this Sunday or Monday (EST), so any help would be appreciated.
