Data Problem
mousemaster
Data Problem
Post by mousemaster »
Hi
I recently drove Laguna Seca and posted this video link to Youtube;
https://www.youtube.com/watch?v=G9TANHopFDM
As you can see, I have no data. I am using an Iphone 4 with an external GPS Embrum along with a BT1 OBDII connector. My son is using an Iphone 5 with the internal GPS and the same BT1 OBDII connector. He has all the data.
I am attaching a sample VBO file from my phone. I don't think it is specifically from this video but it is from one of the runs that weekend.
Can anyone tell me what is wrong? Thank you.
Mousemaster
Re: Data Problem
For the lap shown OBD data is missing (not data in general). Please check the following items:
Check if you find any values in LapTimer ‣ Settings ‣ Expert Settings ‣ OBD Tweaks ‣ Exclude PIDs. In case you do and have not entered it yourself, please remove any value from this row. In addition, please turn off Auto Exclude PIDs in the row above. Finally, please check if you have the latest BT1 firmware installed - they recently updated it to fix some issues with BMWs.
Please let me know what you see in Exclude PIDs. To get an reasonable overlay of your last run at Laguna Seca, please turn off OBD Data in LapTimer Overlay Configuration (shown when overlaying a lap). This will remove the right gauge and use GPS speed instead of the 0 OBD speed.
mousemaster
Re: Data Problem
I had a series of numbers, all the same. 0100 etc. I deleted them.
