Overlay crash when using 2 PiPs
jstaus
Post by jstaus »
I am using GP version on iPad Mini + GoPro2. Works fine to record and sync the GoPro but I have a problem when overlaying the data. I use GoPro as master video and iPad video as the first PiP and the overlay works OK, but if I add a reference video, the overlay process will crash. I moved the GoPro video with iTunes to the iPad so I am not using iCloud...
Also it is quite hard to figure out the matching frame from the GoPro...
Re: Overlay crash when using 2 PiPs
There is a know bug with reference lap overlay I could not find so far. But please check your iOS version first, make sure you run the latest. Next, please follow the steps described in the link below and send any crash logs you find: viewtopic.php?f=8&t=1115
Selecting the correct GoPro frame is indeed hard. Have you checked the video documentation on the step by step description how to transfer and prepare GoPro videos using LapTimer's (half) automatic syncing? If not, please check: http://www.gps-laptimer.com/LapTimerDoc ... hapter.pdf
