exporting .vbo file into Circuit Tools 2 - Missing splits
Posted: Sun Aug 11, 2013 9:37 pm
by jbsGT3
When I try to export one of my laps (BTG Nordschleife) as a .vbo file and load it in Racelogic's Circuit Tools version 2, then I see 6 splits (sections), but only 1 of them has data, the others are void.
Inside HLT I can see the section times fine, but not in Circuit Tools. There may be a compatibility problem ?
Cheers,
Joël
Re: exporting .vbo file into Circuit Tools 2 - Missing split
Posted: Mon Aug 12, 2013 6:47 am
LapTimer exports raw data plus trigger information to the VBO file. CT calculates laps and splits on its own and does not use LapTimer's detection here. As the algorithms differ, CT may have problems where LapTimer has none. You may export and send me ONE lap showing this effect to both .hlptrl and .vbo so I can have a look into it.
Posted: Mon Aug 12, 2013 7:56 am
by bulls23
jbsGT3 wrote:Hi,
Cheers,
Joël
This is what works for me in CT:
Open your VBO, click on the "CT" button on the top left, select Start/Finish wizard, click on "Gate width" until you get the right amount of splits / laps (the number is previewed under the track layout in the pop up windows of the wizard).
Posted: Mon Aug 12, 2013 8:58 am
by jbsGT3
That did the trick! Thanks so much, bulls23.
Posted: Mon Aug 12, 2013 9:10 am
Thanks bulls23, I added this hint to the vbo FAQ.
