Problem with my gopoint BT1
madmarc
Post by madmarc »
I've a problem with my gopoint BT1 and the laptimer.
The gopoint BT1 works with the factory gopoint app and displays data.
My car is a Toyota Prius, the laptimer app shows sometimes OBD datas, but when I start to record its freezed. Speed and engine speed are 0km/h 0rpm.
We testet all parts in another car, Toyota MR2 W3, OBD works fine also I can record data and it shows correct values.
I've also other OBD reader like scan gauge, these work fine with the prius.
What can be the problem with the hybrid car OBD and the software?
Re: Problem with my gopoint BT1
That's any incompatibility between your Prius and LapTimer. Please check viewtopic.php?f=20&t=1500 for the general process how to fix. Oddly, the current GPS/OBD Buddy app is missing the named settings, so please install now (as a reminder), and run through the logging once you have received the next update notice from AppStore. Please do not forget to add the requested information (named in the above post) to your log!
