Confirmation dialogue before purging a route
Posted: Thu Jul 18, 2013 9:33 pm
by Dr_Pippin
Can you add a confirmation dialogue before purging a track's GPS points on the lap list? Normally it would be simple to re-download the map set, except in my case this morning I accidentally hit "purge" instead of "map" for a custom-defined track. Thankfully I had the track backed up in my email.
Re: Confirmation dialogue before purging a route
Posted: Mon Jul 29, 2013 2:58 pm
by gplracerx
I'll second that. I hit purge instead of test. Unfortunately, I didn't have it backed up. All delete functions should have some sort of confirmation in a different part of the screen. The edit function where first you touch edit, then you touch the red hyphen which rotates and brings up a delete button on the other side of the page is how it should be done. You shouldn't be able to delete critical information with a single touch.
