LapTimer Standard and Professional v13 released
Standard and Professional versions 13 are available in AppStore now!
New and updated features include:
- Added OBD II support (currently supported: PCX KiwiWifi)
- All lateral acceleration and approach gadgets are replaced by ODB info once connected
- Fixed 'December lap imports'
- Enhanced vehicle information to have an automatic match with OBD vehicle identification number
- Added a gear shift light (flashes) when OBD II RPM data is available
- Fixed a bug that kept LapTimer from re-linking videos from library
- Reworked the AddOnManager parser code to use less memory (optimized for iPhone 3G)
- Added VIN, voltage, fuellevel, current fuel usage, update rate to OBD displays
- Changes in vehicle Details when edited
- Added a rough calculation of engine power and torque depending on MAF to OBD displays (gasoline only)
- Added OBD data to data recording and import / export
- Added engine rpm to Data Recording Diagram View
- Speed displays use OBD speed (selectively) instead of gpsSpeed when available
- Added session information (date, car, driver, lap number) to video overlay
- Added OBD information (rpm + throttle pos) to video overlay
- Limited video controller rotation to turn to left as overlaying does not yet support turn to right
- Check that lengthy database migrations get a splash screen (especially GPS fixes)
- Fully refactored sensoric to follow a common scheme, new mixing / synchronization algorithm
- Added Sensor List View including system information, current status, and navigation
- Found and fixed a bug in calibration code
- Added a common scheme for send / receive indicators to OBD and GPS display
- Added virtually best lap to Lap Details (calculated time from best sector times)
- Common warning colors for all frequency gadgets, improved update rate calculation
- Changed Timer View layout to look more consistent with other views
- Several smaller bug fixes and display enhancements
Greetings, Harry
LapTimer Standard and Professional v13.1
Due to some problems with iOS3.1.3 devices, I've submitted version 13.1 already. I expect it to be available by the end of next week.
Changes in v13.1:
  • Allow seperate start and stop trigger in the same position to make forward / backward tracks possible
  • Enabled HD Video for iPads and iPad2s
  • Added RPM view (Speedo while OBD is connected)
  • Fixed problem with character encoding in Video overlaying
  • Fixed the problem that crashed v13 on iOS3.1.3 devices
  • Added speed unit to digital display in Speed and RPM View
  • Added "overlay without time" function for the video overlay
  • Show Overlay button as long as device support video overlaying
Callahann
Re: LapTimer Standard and Professional v13 released
Post by Callahann »
If I have the 3G version of the iPad will lap timer pro work on it? I know it is an iPhone app but it is 3G so was wondering if would work.
Callahann wrote:If I have the 3G version of the iPad will lap timer pro work on it? I know it is an iPhone app but it is 3G so was wondering if would work.
Yes it does. Please note that LapTimer Trainer v13.x will have most of the functionality of LapTimer Professional soon. Other than LapTimer Professional it will have full iPad support. Currently it is for data analysis only (no acquisition) so there is no easy solution in case you want to run LapTimer immediately. A good path is probably to start with LapTimer Standard and get LapTimer Trainer once v13 gets available. You may purchase the Trainer version today as it will be raised in price once the additional functionality is available. The upgrade from v12.1 to v13.x will be free of charge.
Please read this announcement http://www.gps-laptimer-forum.de/viewto ... ?f=11&t=16 to get the full story.
Another release is scheduled... Just uploaded LapTimer Standard and Professional v13.2 to Apple.
This update includes:
  • Tuned speed of Speedo View hands
  • Added Dropbox support for export
  • Added OBD data to dashboard overlay CSV output
  • Merged POI List and Lap List views
And the next release (13.3) is submitted to Apple for review. This update includes the changes listed here:
  • Enlarged sensitive area around close and start / stop button in Video View
  • Added full mode 9 scan to OBD support
  • Added gear calculation from RPM and speed (includes new vehicle parameters)
  • Show current gear on video overlay and in several views
  • Added Power Transmission section to Vehicle Details
  • Selected OBD detail is stored / reloaded
  • Added 'Current' button to Vehicle Details
  • Stabilized Lap List with respect to deletions, swipe actions etc
  • Added chart with with rpm / speed ratio to Vehicle Details
  • Changed throttle video overlay to green bar
  • Loosened criterias for coloring of update rate gadgets
  • Changed details information in vehicles list
  • Changed initialization of vehicles
  • Added transition to Lap List View when loading Track Sets
  • Simplified Lap List: removed "Add row" and replace by 'Manage List' button
  • Removed disabling of accessory connection when Sleep button is pressed
  • Add 'Searching...' state to sensors in Sensor List
  • Added 'Not available' status zu internal GPS sensor in case the user or iOS does not allow location services for the app
  • Fixed problem with separate Go / Stop triggers (distance between triggers too short)
  • Added coolant and oil temperature to OBD features
  • Fixed a bug crashing LapTimer when OBD was associated to a vehicle
  • Corrected icon spacing for trigger list items
  • General support for ELM327 based OBD sensors connected via WLAN
  • Several smaller bug fixes and display enhancements
sylvain007
Post by sylvain007 »
Great! Can't wait. Bug thanks for the reactivity
Dear friends of LapTimer,
It seems version 13 becomes a never ending story. Again, I had started v14 development, but received some mails on problems with 13.3 on devices with iOS <4.2 recently. As I still offer 3.1.3 support, I need to double test every new version. In this case, I missed one problem which led to crashes using older iOSes.
To make a long story short, I've just submitted v13.4 (which actually should be 13.3.1). It includes the following changes:
  • Improved status calculation for Track Sets
  • Day / Night skin added, automatically changes between high contrast and black
  • Changed units on RPM plate (Speedo) to show multiples of 1000
  • All values during overlay creation are interpolated now
  • Fixed a minor bug in KML export (ampersands)
  • Fixed a severe bug / crash that occurs with iOS < 4.2
  • Enabled full width video overlays on 4th gen iPods
I hope it is stable now.
c.kuijer@divitec.nl
Post by c.kuijer@divitec.nl »
I'm new here, i purchaced the App, for my IPAD2 and have the following questions:
1. Ipad has 2 camera's, is it possible to have the choice in the next version (front or rear camera) ?
2. The overlay data in 13.1 is small and not in the corners but in the middle of the left side of the screen, preset setting of the Iphone i guess
Regrads, Carlo
Hi and welcome,
On #1: The front side cam does not deliver HD, you are aware? I have currently no plans to support it.
On #2: Will check, I do not have a iPad2 to test yet. In case you would like to early test v14 on iPad2, please send a note to LapTimer@gmx.de using the Contact button. Please add a note on beta registration. Beta testing is not scheduled yet.
