Multicam issue
Posted: Mon Jul 08, 2013 11:21 am
by rscliofan
Hi Harry, I used multicam on Friday for the first time. On a couple of occasions HLT would not detect the multicam. after digging around i found it had self turned off the discover multicam option. This happened on 3 occasions but detected it as soon as I turned on the setting once again.
Just thought I'd mentioned it.
Re: Multicam issue
Posted: Mon Jul 08, 2013 6:07 pm
by karacticus
I believe I managed to do something similar to myself by starting HLT with bluetooth disabled. If I recall correctly, dialog boxes came up, but I wasn't sure what they meant.
I learned...
Re: Multicam issue
Posted: Mon Jul 08, 2013 6:13 pm
That is actually a "works as designed". When BT is turned off, MultiCam operation does not work. In consequence, MultiCam is turned off to give the user an indication it will not work. It is not possible for an app to turn BT on on itself (e.g. when switching MultiCam on), so I thought it is better to prompt the user BT needs to be turned on. Please note it is not even possible to check whether BT is on or off from within an app for iPhones before 4S (i.e. 3GS and 4).
Re: Multicam issue
Posted: Tue Jul 09, 2013 6:18 am
by rscliofan
Ok Harry, BT was on but I was using roqyBT4 so it must not have been detecting it.
Thanks for the reply and hopefully this post will provide useful info to other too.
PIP is a cracking feature.
Re: Multicam issue
Posted: Sun Apr 13, 2014 7:17 pm
by NRGDEAD
It would be cool to have MultiCam detection always on if possible. We are fiddeling with two to three master iPhones and have to turn BT off and on quite a lot when switching drivers, for re-pairing with XGPS and BT1.. ;-)
Re: Multicam issue
Posted: Mon Apr 14, 2014 3:27 pm
I had it like this in the beginning but found out this is simply not possible. Whenever you search for other BT devices, any other traffic is nearly blocked. So if you regularly poll new / changed devices, you will get massive drop outs for GPS and OBD BT devices. But a tip: LapTimer searches for changed MultiCam devices every time you open the video view. So just close it and bring it up again to force a connect.
Re: Multicam issue
Posted: Tue Apr 15, 2014 11:18 am
by NRGDEAD
I meant the button "Discover MultiCams" is off when I turned Bluetooth off. So I have to switch it back on a lot. I'm totally fine with having the actual detection happen when video view is opened. :-)
Re: Multicam issue
Posted: Tue Apr 15, 2014 6:37 pm
O.k., will check that.
