Video Through GoPro Presented on HLT
andover16
Post by andover16 »
Config. using
HLT Petro - latest Rev.
iPhone 5 - Latest software
GoPro Hero 3 - latest rev.
All software up to date. GoPro WiFi is enabled and recognized by iPhone. I can control from GoPro app on iPhone. Even see "Preview" of pix.
However, unable to get HLT to sync to GoPro.
What settings am I missing? There is no "video icon" in HLT. Followed the You Tube video but still nothing.
Thanks in advance. ;)
Re: Video Through GoPro Presented on HLT
GoPro videos cannot be transferred automatically. You need to manually move them. As step by step description is available here: http://www.gps-laptimer.com/LapTimerDoc ... hapter.pdf In case you have problems with conversion / meta data, please search this forum, there are two or three threads around.
andover16
Post by andover16 »
Harry wrote:GoPro videos cannot be transferred automatically. You need to manually move them. As step by step description is available here: http://www.gps-laptimer.com/LapTimerDoc ... hapter.pdf In case you have problems with conversion / meta data, please search this forum, there are two or three threads around.
Sorry, I'm not being specific.
I can not accomplish what is shown in your You Tube video -
http://www.youtube.com/watch?v=YgKrXe0rQT0
Thank you
Please check the doc I have linked above, there is a how-to connect included. Just search for "GoPro". Please check you have set the GoPro wifi password set in LapTimer's Settings, its odd, but required.
andover16
Post by andover16 »
Harry wrote:Please check the doc I have linked above, there is a how-to connect included. Just search for "GoPro". Please check you have set the GoPro wifi password set in LapTimer's Settings, its odd, but required.
In HLT Settings for Multi Cam
It says I need "latest software to discover"
Current HLT Ver.17.06 May 29th, 2013
Thoughts?
From the document linked (please check each of the items):
Preparing GoPro HERO MultiCam Devices for Recording
Before we go into the section on GoPro HERO MultiCam recording, here are the steps you need to perform to connect your iPhone with the HERO.
1. Make sure you have a compatible GoPro cam available: all HERO3 models and a HERO2 plus BacPac will work
2. Make sure you have the latest firmware for your HERO installed (especially HERO3s need an initial update of firmware); check GoPro's home page for details
3. Make sure you have set the correct Wi-Fi mode for the HERO. In the HERO’s settings, select Wireless Controls ‣ GoPro APP; once this is set, you can turn off your HERO again
4. Turn on Wi-Fi operation for the GoPro (HERO3: small button on the right, blue LED blinks)
5. Connect your iPhone to the GoPro Wi-Fi (you have defined the Wi-Fi SSID and password during GoPro setup);
this is done in your iPhone's Settings app: iOS ‣ Settings ‣ Wi-Fi
6. In LapTimer, make sure you have MultiCam operation enabled: LapTimer ‣ Settings ‣ MultiCam Control ‣
Discover MultiCams ‣ ON
7. In addition, enter your GoPro Wi-Fi password in MultiCam Control ‣ GoPro Wifi Password; this is necessary as
every command sent to the HERO requires this password - no good practice from my point of view
To test connection, switch to the Video View within LapTimer - you should see the gray little cam in the status bar turning white; in addition, you should see communication going on between Master and Satellite shown by small green and blue indicators; the HERO will beep and turn the cam on - you are ready to record. Please note that instead of getting a live view, the HERO will be shown as a placeholder with blinking LEDs.
In case it does not work, please try the GoPro app available for free on the net. It uses the same mechanism.
andover16
Post by andover16 »
I appreciate the time being taken. The GoPro Wi-Fi is connected to the iPhone because it can control the GoPro app. I can see the "Preview" screen on the iPhone app.
I did follow the instructions in the PDF, however, when I get to this step -
"6. In LapTimer, make sure you have MultiCam operation enabled: LapTimer ‣ Settings ‣ MultiCam Control ‣
Discover MultiCams ‣ ON"
I get the following message in HLT when I try to toggle "ON"
Warning!
"This feature is not available in this app edition. Please check for upgrades available."
I have Ver.17.0.6
Aha... MultiCam is a Grand Prix Edition feature. To upgrade your Petrolhead to Grand Prix, please check the "Tracks" tab. You will find the upgrade right in the top. Without GP you need to operate the GoPro manually. But even in Petrolhead, you can transfer the GoPro video to the iPhone, link and sync it to any laps, and overlay it.
andover16
Post by andover16 »
OK, upgraded to GP edition.
Issues:
Still not getting live video stream from GoPro to HLT. GoPro Hero "camera", no actual video, show in the PiP window. Master (Lap Details) is the iPhone.
LapTimer does not present a life video for GoPros, it shows a camera placeholder only to give you an indication the HERO is connected (blue LED blinking) and potentially recording (blue + red LED blink).
