Time shift correction for GPS vs ODB data
Posted: Sun May 26, 2013 11:11 pm
I was using the latest version of GrandPrix on iPhone5 at "Infineon" Raceway (which is now called Sonoma raceway and most people recall as Sears Point...)
I have a GoPoint BT1 ODB device and an XGPS150 with the 10Hz software installed.
When looking at the charts of lap data, there is a consistent 2.5 second delay in the GPS vs the ODB speed data. I notice that as well when I'm on the track as the "beep" that I've passed a trigger point seems to happen about 2 seconds after the physical spot of the trigger.
A consistent 2.5" delay in getting a position fix from the GPS to the software isn't really a problem for calculating lap times, but it does make for a problem when trying to use the lap charts to make sure I'm shifting and throttling at the right times and places.
A configurable option (perhaps post-processing) for delaying the ODB data points by a specified offset would be nice to have.
It's also interesting to see the differences in the GPS speed fixes vs the ODB speed fixes. Not sure which is more accurate, but I would guess it's the ODB as the GPS fixes seem to be more heavily filtered.
I've attached a hpltrz file of a sample lap so you can see the offset.
