None suction mount
Posted: Fri May 17, 2013 4:37 pm
by rscliofan
Ok so I found a UK supplier of the ram mound adhesive mount.
I've ordered that now.
Re: None suction mount
Posted: Wed Apr 09, 2014 7:56 am
What is your experience with it and can you send a link? Thanks!
Posted: Tue May 06, 2014 9:23 pm
by rscliofan
Sorry for the late reply Harry.
I used anymount.co.uk but I no longer think they trade
I went with
The adhesive mount with 1" ball
Then the short arm
1" ball diamond base
And iPhone 4S cradle
I am massively impressed I have to say. The mount is very, very solid and never been questioned on track.
You get no shake even with a stuff chassis setup and running apex's.
I was so impressed I went out and bought a second iPhone to use as a multicam and second mount for it as above.
Posted: Sun Jun 01, 2014 2:40 am
by gplracerx
Is that the Ram Mount RAP-B-378U, Ram Mount Flex Adhesive Base with 1-Inch Ball, Black? I'm looking for something less flexible than a suction cup mount, but I'm still reluctant to glue something to the windshield. Glue exposed to sunlight, except for the glue that manufacturers use to glue rear view mirrors, tends to fail. I've never had much success with after market kits to reattach rear view mirrors that did fall off.
Posted: Mon Jul 14, 2014 5:12 pm
by rscliofan
gplracerx wrote:Is that the Ram Mount RAP-B-378U, Ram Mount Flex Adhesive Base with 1-Inch Ball, Black? I'm looking for something less flexible than a suction cup mount, but I'm still reluctant to glue something to the windshield. Glue exposed to sunlight, except for the glue that manufacturers use to glue rear view mirrors, tends to fail. I've never had much success with after market kits to reattach rear view mirrors that did fall off.
Sorry I didn't get a notification until now!
Yes that's the one. I have two on the car for use with multicam and don't even notice they are there.
Posted: Thu Sep 04, 2014 6:09 pm
by GlnkNL
It's better than the suction cup but there is still a little flex in the ball/base of the flex adhesive base because it's completely made of plastic.
Posted: Mon Sep 08, 2014 8:33 am
by rscliofan
Mine is solid with next to zero flex from experience and certainly not noticeable on the videos.
You can also get it in metal form but you add weight which may result in movement hence me going plastic.
