I've used HLT at 6 different tracks, and after each track day I always delete the POI's & triggers. I do this because I'm worried having multiple track POI's will confuse the software to know what track I'm at.
Do most of you just keep the track info or reload it prior to driving?
Keep track POI's & triggers, or reload for each event?
Re: Keep track POI's & triggers, or reload for each event?
Having several different track sets on the device will not confuse it. Since it's GPS based, HLT knows exactly where it is
The only situation several track sets might be a problem is when you have different configurations of the same track loaded. In that case, HLT shows you a warning and ask if it should delete the other track set.
