PIP Ref video without showing time info
xps911
Post by xps911 »
I've just upgraded to the full version for Picture in Picture against ref video. Which works great however I need to have the video without the laptime showing, if I select it to no, the PIP ref does not show :(
How can this be resolved?
Re: PIP Ref video without showing time info
Just to understand: in Overlay Configuration you select OFF for "Date and Timing" and you do not get the Reference PiP anymore? Need to check, that is not intended. In case it is like this, I will try to fix it in an upcoming release.
xps911
Post by xps911 »
Yes
xps911
Post by xps911 »
Just tried on latest version:
Ref video: On
POI / Speed: On
Countdown: Off
OBD II (greyed out)
Date & Timing: Off
and it worked as expected :)
However under the ref video, it has "reference sector" and a time being shown
Thanks, that saves me an hour :-) The last point is not unexpected. Removal of reference times is not supported currently. I have added it to my list (see above).
xps911
Post by xps911 »
No problem, just tried on latest version this setup also:
Ref video: On
POI / Speed: On
Countdown: On
OBD II (greyed out)
Date & Timing: Off
also worked as expected
xps911
Post by xps911 »
