How to retrieve the last lap if you don't pass start/finish
dasams
Post by dasams »
Harry:
There was an incident on track yesterday and we were black flagged. Hence, I did not cross the start/finish line. I'm trying to retrieve the video since it happened in front of me. I have the data in the lap list but no video. The video is also not present in the Camera Roll. Is there any way to retrieve the video from HLT?
Thanks, Dave
Edit: When I got off track, the video was still running so I stopped it my hitting the 'x' and then clicking on the Finished button.
09 Carrera S - Black, 6 sp, Carrera red full leather with deviating black, adaptives, navi, XM, etc
06 Cayenne S - Crystal silver, air suspension, bi-xenon, navi, sirius, etc
Re: How to retrieve the last lap if you don't pass start/fin
Please check if you see the video in the Video List. If not, it is not available any more. There has been a usage pattern in 16.6 that could lead to situations like this. I recall it is fixed in the upcoming version 17.
dasams
Post by dasams »
Harry wrote:Please check if you see the video in the Video List.
Found it in the video list as the full 21 min session is there! The lap timer also recorded the data from the lap of interest but did not automatically link to the video. Is there a way to do this in Lap Timer or do I have to use a different solution? Dave
To link a video and a lap, follow these steps:
LapTimer ‣ Lap List ‣ select lap to link video too ‣ press Edit ‣ press Add Video ‣ select your 21min video ‣ set the sync point when prompted
The sync point defines the position in the video that matches THE END of the lap, please select accordingly.
P.S. Harry's LapTimer Documentation - Videos
dasams
Post by dasams »
Harry wrote:LapTimer ‣ Lap List ‣ select lap to link video too ‣ press Edit ‣ press Add Video ‣ select your 21min video ‣ set the sync point when prompted
It worked great!!
Thanks for the feedback :-)
