Qstarz 818XT refresh Rate only 4 Hz
spunkt81
Post by spunkt81 »
I am using roqyBT4 with a Qstarz 818XT GPS-mouse.
Unfortunatelly Harrys laptimer receives gps fixes only with 4 Hz.
I am pretty sure that since i upgraded to a iPhone 4S.
With my old iPhone 4 a had refresh rates >8Hz. Also my iPad works with high refresh rates.
My current config:
iPhone 4S, iOS 6.1.1, jailbroken
with roqyBT4 1.3.2-2
Does anyone have the same problem?
Re: Qstarz 818XT refresh Rate only 4 Hz
Which iOS version do you use for the old iPhone4 and the iPad?
spunkt81
Post by spunkt81 »
My iPad is on 6.1 and on my old iPhone 4 iOS 5.0.1 was installed.
On my current iPhone 4S i had this problem since 5.1.1
spunkt81
Post by spunkt81 »
I tried this tweak: viewtopic.php?f=19&t=1044
Seems to work quiet good. There are more fixes recorded and HLT shows a refresh rate constantly of 9,8 Hz. Does this mean that my gps mouse delivers fixes with 9,8 Hz? Because: When i turn off my mouse the refresh rate does not change.
The update rate displayed is a measured value. I have no idea why you see 9.8 Hz after having disconnected the GPS. For supported accessories ;-) LapTimer falls back to internal GPS, the update rate will go down from 9.8 or whatever to 1 Hz slowly.
Mike S2k
Post by Mike S2k »
I use BT stack GPS with my 818xt and works fine
spunkt81
Post by spunkt81 »
i'll try it on my next track day and give a feedback.
roqyBT
Post by roqyBT »
I updated roqyBT4 to 1.4 for best rates updates and to correct issues people could have sometime (disconnection).
You should see full rate now.
thanks,
roqy
spunkt81
Post by spunkt81 »
Unfortunatelly, after updating to 1.4.0-1 the refresh rate still sticks to 4 Hz.
But the trick viewtopic.php?f=19&t=1044 seems to work fine with 10Hz even with an additional gopoint BT1 coupled by iOS bluetooth menu.
WilsonSteele
Post by WilsonSteele »
I use the BT-Q818XT with roqyBT4 with great success at 10Hz.
On my GPS unit, the on/off switch is actually a 3 way switch, the position are "on / 1hz / 10hz"
However, if you download the QStarz software, and connect the GPS mouse to your windows ocmputer by USB, you can configure these two positions to whatever refresh rate you want.
Back when I used HLT with a palm device, I had to set the maz rate to 4 Hz, the older BT connection didn't have nay higher data rate. So I had one position set at 2 Hz, and one position set at 4 Hz.
http://www.qstarz.com/download/GPS_Tester.rar
Now, on the iPhone version, I just use the 10Hz data.
HOWEVER, while the GPS Rate on hte GPS scrren says data at 10Hz while lapping, when I look at a recorded file of a lap in LapList, the GPS Sensor says Internal @ 8Hz, with something like 1047 fixes (GPS, ACCEL) in a 2 min lap.
I am not sure why that is, perhaps a bug for Harry to look at.
SpecMiata #159 '94 1.8L
SoCal NASA, USA
