2) yes
3) see 1)
4) the PC is only faster in case you use hardware acceleration - do not underestimate what the iPhone can do.
5) yes, planned for Spring 2013. Please do not expect full feature support in the beginning
Did you know you can continue to use your old iPhone without cellular service after you've switched to a new device?OverRev wrote:...I m looking forward to the Android version, honestly HLT is the only program/reason i stay on iPhone or else i would have switched to GalaxyS3 months ago....
You are joking, aren't you? Given the amount of work that must go into HLT, not to mention the time spent on support, Harry near enough gives it away already.OverRev wrote:.... and i hope current user of the iphone version would get a discount on the android version..![]()
http://www.gps-laptimer.de/Video.html -> 404 Not foundHarry wrote:Yes, that's possible. I have outlined the process here: http://www.gps-laptimer.de/Video.htmllunat1ck wrote:What I would really like to be able to do is two things: first, I would like to be able to import the video from the primary GoPro (the one on the harness bar) and then overlay the LapTimer data on top of that. Is that possible?
Search for "USING EXTERNAL VIDEO SOURCES" to get the steps. The description is not down to every button click but should give you an idea. In case you need more assistance, I'm happy to help. And I certainly appreciate the video created and your feedback on how you did it and how it works.
