Support for GoPoint Tech BT1 OBD-II
Re: Support for GoPoint Tech BT1 OBD-II
The gopoint has no ELM327 but a different interface. So I doubt it will work through roqyBT4.
LapTimer assumes roqyBT4 connected devices are ELM327 compatible.
Atre777
Post by Atre777 »
Bought the BT1 for €92,44 EUR including shipment to germany.
WizardKing
Post by WizardKing »
I wasn't able to get my BT1 working with HLT using RoqyBT4.
Problem is completely solved now . . . as I have installed the fantastic v.16 !
" It's better to burn out than fade away . . . " The Kurgen, Highlander
My vids, many using HLT ; http://www.youtube.com/user/WizardKing6
Thanks WizardKing, good to hear.
Bgibbs_1
Post by Bgibbs_1 »
any more confirmations of using BT1 with another Blue tooth device like the dual Xgps150 with v16.0?
lisocayman
Post by lisocayman »
Bt1 works perfect
tdott
Post by tdott »
Ordered!
Can't wait.
fluppie00
Post by fluppie00 »
Bgibbs_1 wrote:any more confirmations of using BT1 with another Blue tooth device like the dual Xgps150 with v16.0?
I also use them together :). Working fine!
Ray_S
Post by Ray_S »
Also tested the BT1 together with XGPS150 today - works great, thanks to Harry!
Porsche 996 turbo Cab
O.k., so I can answer questions whether theses two work together, with a clear "YES". Thanks!
