Firmware 2.11.0 for RaceCapture/Track
aaronpoweruser
Re: Firmware 2.11.0 for RaceCapture/Track
Post by aaronpoweruser »
Harry wrote:I have just check the direction issue based on gplracerx's input. It is broken due to the circular characteristic of degrees (0-360°). Some math to do here. As LapTimer's trigger detection uses the direction to verify before / after conditions (compared to start / finish line), this may lead to missed triggers too. A fix will be provided for 21.0.7, but it will require some days (traveling currently).
Has this update been pushed for android?
koiseptember
Post by koiseptember »
Yes, but I'm trying to determine the level of the problem, not solve it. If it's the interface with the app, it's something you will need to fix. If it's on a more fundamental level, they have a problem. Since it doesn't work with the older version of the app either and the new version hasn't been released for iOS, running them in parallel isn't really an option anyway.
goldenslot
MrBlah
Post by MrBlah »
track day this weekend, I've not attempted to use hlt for a while, anyone know if racecapture is working with it now?
steved0x
Post by steved0x »
I tried to use it last weekend with RaceCapture/Track and ran into the issue of HLT would connect to the RCP but the update rate for the GPS and the OBDII would immediately drop to zero, so I went back to just using HLT with QStarz 818XT.
MrBlah
Post by MrBlah »
it failed on me, I had to use solostorm instead. Solostorm is nice but the video overlay is not as good for track days, does not have the neat corner speed stickies and does not seem to like to talk to my gopro as well
jaytee
Post by jaytee »
Tried it out over the weekend and had a similar experience: HLT would recognize the RCP3 GPS & engine data, then drop it shortly after.
Anyway to troubleshoot it? Harry, do you need someone to perform any testing?
Please read about the RaceCapture integration here: viewtopic.php?f=39&t=4244
I will return to this topic during Winter, but cannot adjust the integration for each of RC's firmware updates.
MrBlah
Post by MrBlah »
harry are you still planning fixes for racecapture this winter? Mine still does not work with HLT, never detects laps
MrBlah
Post by MrBlah »
any updates on getting it working? I had to use solostorm last season and I would like to switch back to HLT
7racer
Post by 7racer »
Hey Harry,
I recently switch to MoTec for my ECU and it looks like one of the easiest ways to export CAN info is via Racecapture.
I was about to purchase the Racecapture track or pro until I found this thread.
Is it compatible still?
is there another way I can get the CAN data to transmit to Harry's?
