Dual XGPS160
u.loeffler
Re: Dual XGPS160
Post by u.loeffler »
Hey,
i can in the App under GPS change the "Rate" 1 Hz, 1,0 Hz and 12 5 Hz (NMEA)
Make ist an Difficult by the Record???
Re: Dual XGPS160
The only reason to reduce the update rate below 10 Hz is when you observe bandwidth problems from other Bluetooth connections.
widarecu
Re: Dual XGPS160
Post by widarecu »
Is the Dual's compatibility issue with the latest iOS still happening? Just considering to check my Bad Elf for either Dual or VBOX,
Regards,
Wilson
Kojiiro
Re: Dual XGPS160
Post by Kojiiro »
Hello! I’ve been linking for a while and r gently decided to register to ask my question. I currently have an iPhone 6s+ and Gp with ver 21.1. While I thought the phone was good enough, a fellow on the R3 forums mentioned he used a dual xgps150. Seeing as the 160 is rated at 10 hz versus 5 on the 150, I was planning on purchasing that instead, but read the part about current issues between iOS and the 160. Is this still the case? Any resolution in sight? I read one of the more recent posts stating you are waiting on a reply from ththe dual technician. I also considered the Push smart gauge a few months ago but just read on here that it seems there is no more support. Any other suggestions for a gps/logger? I would like 10 hz or more if possible, but I don’t want to spend too much time messing around with it.
Re: Dual XGPS160
I think I need to remove the disclaimer on the compatibility page. If I remember right, the firmware version “2.4.5" / "3.4.5” (depends on model) fixed the problems discusses. You may want to search the forum, some users replied the above firmware version fixes the issues observed.
widarecu
Re: Dual XGPS160
Post by widarecu »
I can confirm Dual XGPS160 is working fine with iOS, I'm running iOS 11.1.2
gvelilla
Re: Dual XGPS160
Post by gvelilla »
I can also confirm the dual 160 is working at 10hz with the newest firmware without issues.
micblom
Re: Dual XGPS160
Post by micblom »
Maybe relevant for some: my jailbroken iPhone 7+ (11.1.2) will not properly connect to the XGPS160, it shows as connected under BlueTooth preferences, yet neither HLT or the Dual App can detect it. If I restart non-jailbroken, everything works flawlessly.
