But please be aware that version isn't as thoroughly tested as the original version. But I'm currently not aware of any problems with it
RejsaRubberTrac - 16 zones tire temps - bluetooth sensor
- Magnus Thomé
- 10 or more Posts ★
Re: RejsaRubberTrac - 16 zones tire temps - bluetooth sensor
That sensor should work with the updated "work in progress" beta version two other guys helped with, read here https://github.com/MagnusThome/RejsaRub ... orking-kit
Bleak December
- 20 or more Posts ★★★
Awesome! Thank you for your quick reply
I will be updating here if I find something along the way.
Bleak December
Hi Magnus
I am having problems on last step when upgrading the bootloader on the Feather (as I got the error messages when pushing the code). Hope you can point me out to some simple procedure, because I cant wrap my head either on Adafruit site or info in YouTube…
Thank you!
Bleak
Thank you!
Bleak
- Magnus Thomé
Upgrading the bootloader I can't help you with, I think I've only done that once on some odd board years ago. Why are you looking at that?
Bleak December
Hi, no problem will keep investigating
COM is ok, so the messages i received are as mentioned in your Github:
File "nordicsemi\dfu\dfu_transport_serial.py", line 243, in send_packet
File "nordicsemi\dfu\dfu_transport_serial.py", line 282, in get_ack_nr
nordicsemi.exceptions.NordicSemiException: No data received on serial port. Not able to proceed.
Seemingly related with the bootloader needing an update. Can’t figure it out yet
